we are working on getting license for manufacturing apps.
So meanwhile we want to give a try with Trial version.
Does this trail version of manufacturing apps will run on desktop grade machine which is having windows 7.
Raji.
Greetings Raji,
Yes, you can install the Express version on a Windows 7 operating system. Per the ThingWorx Manufacturing Apps Setup and Getting Started Guide, under the Express Installer section, "If a warning appears for installing on an unsupported platform, such as Windows 7, you can proceed with the installation."
Best regards,
Steven M
Greetings Raji,
Best regards,
Steven M
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
