Can we install Operator Advisor 8.4.1 in Thingworx Composer 8.4 Version ?
koushal
Hi All,
Can we install Operator Advisor Extension in Thingworx 8.4 and in future I just want to upgarde the Operator Advisor to 8.5 without upgrading the Thingworx Version?
  Is it compatible that we have Thingworx Version 8.4 with Operator Advisor 8.5 version?
1 ACCEPTED SOLUTION
With Thingworx 8.4 you can use any OA release of branch 8.4 only
7 REPLIES 7
No, Thingworx version 8.4 is not suitable with Operator Advisor 8.5. You have to upgrade platform first before Operator advisor.
koushal
(To:vinakumar)
Hi ,
What is minimum Thingworx Version needed for using Operator Advisor ?
I know that Thingworx 8.5 .1 is compatible with Operator Advisor 8.5.1.
What Thingworx Version does Operator Advisor 8.4.1 support?
First release of Opeartor advisor comes with Thingworx version 8.4
koushal
(To:vinakumar)
For the same thingworx environment i.e. 8.4 till which version we can upgrade the Operator Advisor  version 8.4 ?
koushal
(To:vinakumar)
Thanks. For using Operator Advisor 8.5 version or later, we need to upgrade the Thingworx version to 8.5. Is it correct ?
Correct.
