I have a device connected over Modbus TCP/IP channel and logs data correctly. OPC quick client shows correct value. Once i turned off device, data quality is bad because of no communication. when i restart a device, there is no good data seen in OPC quick client. I have to delete channel and device and re-add it again along with tags. Once i will do it, it will start showing good quality data. Everytime i can not do that when i am using this during live production. Can you please suggest where i have to focus for this?
Sometimes it has been observed in log that it shows error code 10061. 'Socket Error Occured connecting'. Error=10061. 'No connection could be made because the target machine actively refused it'.
@Mihir_solanki : I see that you have already raised a Salesforce ticket for this issue for Kepware. Someone from kepware team would respond on that. Please follow up on that case henceforth for this issue
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
