Hi experts,
I'm trying the ThingWorx Manufacturing Apps according to the guide here: https://developer.thingworx.com/en/resources/guides/configure-manufacturing-apps/configure-factory-simulator-data.
One of the steps is to open the DemoFactorySimulator.opf in Kepware, after this step I should see "ThingWorx Native Interface , Connected to Thingworx" in the Kepware's log console, however I see "ThingWorx Native Interface Connection to ThingWorx failed. | error = could not initialize a secure ".
My environment: OS:
What I have verified:
Is there anyting else I missed for connecting to Thingworx ? could you advise ? Thank you Regards, Sean
hey @seanccc
your screenshot shows that your configuration for the Thingworx interface in KepServerEx tries to connect to port 8090 and not to 9080.
Seb
hey @seanccc
Seb
Hi Seb,
Thank you for checking this. You're right , I made the mistake ! It works after correcting the port number .
Sean
