Connection to Thingworx failed
SOLVED
Re: Connection to Thingworx failed
Hi Himanshu,
I just installed both Industrial connectivity(8.4.66) and Thingworx foundation trial(8.4). Getting the same error as discussed in this thread. I have attached both my Thingworx instance and property of IC.
Raj
Hi @RV_7 ,
Can you set Disable Encryption to yes and try to connect.
If this does not work, additionally change localhost to 127.0.0.1 in the host property.
Himanshu
Hi Himanshu,
It works. changing the host to '127.0.0.1' did the trick.
Raj
I got the feedback from RnD that the issue could not be reproduced.
Do you have the change to test it with the newest KepServerEx version?
Seb
Hi @grantji.
Since a solution was found for the issue you were experiencing, please mark the appropriate reply as the Accepted Solution for the benefit of others with the same issue.
--Sharon
