Connection to Thingworx failed
Re: Connection to Thingworx failed
I just had the same problem, and replacing localhost with 127.0.0.1 also resolved it (thanks!). I have firewall switched off, so it must be something different, the way Kepserver resolves names I guess.
I also guess the problem related to Kepserver settings. I have changed the hosts file (enable the line "127.0.0.1 localhost" ) and switched the Windows Firewall off. Thanks!
@grantji  and @rlegat
could you please give me the KepServerEx version that you are using.
I want to check with PM if that is an issue with KepServerEx.
Thanks Seb
With me, it's ThingWorx Industrial Connectivity Platform 8.4.66, Drivers are all 6.6.350.0.
@rlegat
do you use windows server as OS?
Seb
No, it’s a windows 10 VM.
Hosts file maps localhost to 127.0.0.1.
We just tested it on Win 10 without issue but i faced the issue with Win server.
Thanks to all for your replies!
We will try to find the reason for this behavior and get back to you.
Seb
Hi Seb, I downloaded latest trial version on the official website. Just I checked the version of "Thingworx Industrial Connectivity", it is 8.3.65.  My OS is Windows Server 2012, installed on Virtual Machine.
Grant
