Could not find extension (RemoteAccessExtension:0.0.0) depended upon by SCO_Common-extension:8.4
SaranKarthick
Hi @hrajpal ,
I'm also facing same issue, but i couldn't find the RemoteAccessExtension in my support portal.
Is it license based? Also kindly let me know if there is any workaround.
Saran
Hi @SaranKarthick.
What procedure are you using for accessing the downloads?  If you're linking to it from the Sales order, it may not show up.  Try these instructions:
  1. Navigate to PTC Support
  2. Select Download Software
  3. Select Order or Download Software Updates
  4. Select ThingWorx Platform
  5. Expand Release 8.4
--Sharon
Hi @SaranKarthick.
--Sharon
Thanks @slangley . I was searching under PTC Smart connected Products category.
Saran
