Custom Status in addition to the default ones
Regular Member
Is there a possibility to add another status beside the 6 default ones in the configuration and setup app ?
I can only find the customization of the expressions in the guide.
Or can i rename the "UNPLANNED_DOWNTIME" in e.g. "ERROR"  ?
Re: Custom Status in addition to the default ones
Hi @ninja ,
Equipment status are defined in the code itself so it is not possible to rename it using customization.
Himanshu
It causes erros when i edit the code.
But i found out that i can change the descriptions in the localization tables and it works !
