Default Tags given by Kepware
SOLVED
In the OPC Quick Client, Kepware has few default tags like data logger, system tags and scan mode and demotion tags apart from the tags that I create. What is the purpose of these tags? Is there any documentation to learn about these tags and its use?
Please provide some ideas.
Thanks in advance,
Shalini V.
Re: Default Tags given by Kepware
@svisveswaraiya- You can refer to Kepware documentation which has details about these tags however it might cover everything you need.
https://www.kepware.com/getattachment/5759d980-7641-42e8-b4fb-7293c835a2f9/kepserverex-manual.pdf
-Durgesh
-Durgesh
