How to add multi equipment in Configuration and Setup UI ?
SOLVED
Aquamarine
Hi All
If we have many devices in kewpare, how to batch import all device configuration ?
Re: How to add multi equipment in Configuration and Setup UI ?
Hi @LeslieK.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
