How to create a Service and a subscription to the alert?
SOLVED
mhayes66
Participant
Thanks Milan,
I am brand new to this, so is there documentation on how to create a Service and a subscription to the alert?
-Michael
Re: Alert status not updating Sigma Tile?
Hi Michael.
I assume you are referring to the ThingWorx Manufacturing Apps Setup and Getting Started Guide 8.0.1:
https://support.ptc.com/WCMS/files/173133/en/ThingWorxManufacturingApps.pdf
If so, you might try checking the previous 2 chapters.
We also have some articles in our knowledge base that may be helpful:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS240914&posno=1&q=alert%20subscription&Doc...
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS228527&posno=11&q=alert%20subscription&Do...
Let us know if you are unable to find the answer to your questions.
--Sharon Langley-Anderson
Hi Michael.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
