I was reading about it here: https://www.ptc.com/en/products/service-lifecycle-management/thingworx-asset-advisor
Where to download it from? I was trying to go to: ThingWorx IoT Marketplace
but there is no download page. I have Thingworx 8.1.1 installed on Ubuntu AWS AMI instance with Postgres DB.
There is also an interesting application to see how I can build mashup similar to this app:
I need to build an app similar like Axeda (with its pre-builit asset management screen and to drill down to each asset/device to see its status, alarms, data values) and I was wondering if I can start from an existing Thingworx app and modify it and go from there?
In the case of asset advisor this seem to be an app so I was wondering how to start creating my own app based on this or other apps available (are they just custom extension with packaged entities (like advisor app) : Thigns, MediaEntities, Mashups, ThingTemplates, DataShapes, Masters etc.
I would like to build an asset list page with a link to a detailed page like asset advisor app shows:
Hi Rad.
Asset Advisor for Services is included in the license for ThingWorx SCP. Please reach out to the Sales team for obtaining the proper entitlement. Once you have done so, the software called Service Apps can be downloaded from PTC Support at the following url: https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWA
Asset Advisor for Services is a starter app designed to provide out of the box capabilities but built with the intent that it can be customized. The customization guide can be downloaded from the following url: https://support.ptc.com/WCMS/files/173135/en/ThingWorxManufacturingServiceAppsCust_8-1-0.pdf
Please let us know if you have further questions.
--Sharon
Hi Rad.
--Sharon
Hi Rad.
If the previous response answered your questions, please mark it as the Correct Answer. If you have further questions, please let us know.
--Sharon
Content Move Notice (Dec. 2018)
ThingWorx Code Examples boards are now merged into IoT Tech Tips under the Code Examples label.
The Service Apps board is now merged into the Manufacturing Apps board.
