IoT Gateway service stopping
JMartinCrane
1-Newbie
I am trying to follow the sample setup from PTC and am having difficulty in that the IoT Gateway starts, finds the JRE
"KEPServerEX\IoT Gateway IoT Gateway using JRE at [C:\Program Files (x86)\Java\jre1.8.0_191]"
Then the IOT Gateway service stops.  Why?  How do I determine the cause of this?  The Custom Controls Advisor cannot be used due to connectivity issues.  Thanks,
John
3 REPLIES 3
Hi @JMartinCrane,
In trial edition (without license) KepServerEx, IoT Gateway service works for 2 hours and after that it stops by itself.
To fix the problem you need to navigate to the KEPServer Icon on the bottom right hand corner, right clicking and selecting "Stop RunTime Service" and then right clicking and selecting "Start Runtime Service".
This will again start service for 2 hours.
Himanshu
Hi @JMartinCrane ,
Hope you are doing good.
In regard to this post, if the previous response provided you with the guidance you were looking for, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
Himanshu
SebB
(To:JMartinCrane)
@JMartinCrane
for the IoT Gateway you need the JRE 32 Bit version on your system.
you can download it from the oracle page: https://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html
Seb
Seb
Principal Solution Experience Architect
PTC
