KepServerEX for communicating between two OPC UA Clients?
andis59
We have two OPC UA Clients (PC) and want to communicate between them using KepServerEx.
There i no PLC involved!!!
Is this possible?
if it is, which driver should I use?
The clients are Pi System and a customer specific program.
Fred_Loveless
(To:andis59)
Greetings, you will want to use the Memory driver. It can be configured to persists values on server shutdown but more importantly because it is memory based and does not use a PLC all communications is processed via local memory cache.
Fred_Loveless
(To:andis59)
andis59
(To:Fred_Loveless)
Worked like a charm!
I have succeeded using the ODBC Client driver and MS SQL Express server (which was what the Swedish distributor recommended...), but this is much simpler!
Thank you very much!
// Anders
