Following this guide, on 8.4.0 I am running into this issue. I have to log into composer and then navigate to the runtime. Login fails in the Runtime/WelcomeForm. This is fine to play with the trial edition, but for production I need to direct people to the Welcome screen to log in. Is this just a trial edition bug?
Hi @mikefinch87 ,
There is no such bug. We can login to Welcome screen directly by entering credentials.
Are you getting the login prompt like below while accessing Welcome page (http://hostname:port/Thingworx/FormLogin/Welcome)
What error you are getting while putting credentials here.
And which users are facing the login issue. Did you tried with Administrator and other users as well.
Himanshu
Hi @mikefinch87 ,
Himanshu
Appears to work today. Sorry, not sure what changed.
