Missing production advisor
Bach
I am trying to install Thingworx Manufacturing App. The "Production advisor" is missing. Does anyone know how i can fix this?
bha1
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:Bach)
Hi bh1.
This is usually the result of a licensing issue.
We would first need to validate your entitlements but I would need more information to do so.  If you can please update your profile with email address, company, etc., I will be able to determine if we would need a case for troubleshooting this issue.
7 REPLIES 7
slangley
23-Emerald II
(To:Bach)
Hi bh1.
It could also be the Access Control. The logged in user must be assigned to Production Manager role. Otherwise, you will not see Production Advisor Tile.
Varathan
Bach
(To:vranganathan)
Thanks for the suggestion. I was logged in as Administrator. I also tried adding Admin to that role and it didn't work.
PTC checked my TWx license, and it was clear that this is a licensing problem.
Bach
I understand that.
My point was it could also be from Access Control. I want to add it to this thread for future reference.
Varathan
hrajpal
(To:Bach)
Have you imported service apps extensions too ?
Himesh Rajpal
Bach
(To:hrajpal)
yes. It was a licensing problem. Everything is running fine now.
mapathak
(To:Bach)
Hello Bach,
Thanks for letting us know.
If our response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Manoj Pathak
