Regarding OEE graph
SOLVED
Regular Member
Regarding OEE graph
What is the Kepware configuration is needed to display OEE graph in Manufacturing app?  Do you have any OPF file, which will give result of OEE, Performance, etc. of a machine?
Hema
Re: Regarding OEE graph
The link below has the instruction to setup demo data set. Towards the end of the page you will see a DemoSimulatorPackage.zip for download. It has the opf file.
https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started/Configuring-the-Apps-with-...
Varathan
Hi Hemalatha.
A video is available on the ThingWorx Manufacturing Apps portal which may be able to answer your question.  Login with your PTC Support ID to the following url:  https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Get-Started
Scroll down until you locate the video indicated in the screenshot:
Please let us know if this answers your questions.
--Sharon Langley-Anderson
Varathan
Thanks for your reply, this is what I expected
Hema
Thanks Varathan
