The default status configuration error from PhysicalAssetThingTemplate
vinesh
8-Gravel
As shown in attached image, I am trying to add an asset in the Asset advisor Configuration page. But I am getting the error as shown in the pic. I tried editing the PhysicalAssetThingTemplate template but it is not editable as it is from the extension. Am I missing out something here?
But I have no problem in doing the same in older version of Thingworx.
Current Version: 8.5.0-b12.
1 ACCEPTED SOLUTION
vinesh
8-Gravel
(To:vinesh)
SOLUTION:
I had missed out the "Post Import Database Configurations" steps as given in the https://support.ptc.com/help/thingworx_apps/r8.5/en/#page/thingworx_apps%2FThingWorxAppsSetupConfig%2Fimporting_the_thingworx_apps_extension.html%23.
Upon performing those steps, there was no such warnings,
6 REPLIES 6
hrajpal
(To:vinesh)
Go to Thingworx Composer and run the service CreateTables for the thing PTC.SCA.SCO.DatabaseManager. After execution of this service, try the equipment page again.
Himesh Rajpal
vinesh
8-Gravel
(To:hrajpal)
Thanks for the quick reply. I tried doing what you said but got error. here is the scrip log details:
1. Error in: PTC.SCA.SCO.DefaultStatusManager.ReloadStatusDefinitions javascript service
2. com.thingworx.dsl.exceptions.DSLRequestProcessingException: Execution error in service script [ValidateDefaultStatusExpressionsByTemplate] :: An error has occurred. Contact your administrator for further details.
Everything works fine till 8.4 update. The problem is only in 8.5.
vinesh
8-Gravel
(To:vinesh)
Also to mention, I have carefully added the relavent extension package for 8.5. I have followed the instructions as given by PTC to import the Thingworx Manufacturing apps extension package.
vinesh
8-Gravel
(To:vinesh)
Looks like there have been some buggy changes made in the 8.5 version of Manufacturing apps extension. As a workaround, I imported the 8.4 version of Manufacturing apps extension to 8.5 version Thingworx and it worked without any issue. I hope I won't face any problems later.
slangley
23-Emerald II
(To:vinesh)
Hi @vinesh.
Just want to make you aware that running ThingWorx Manufacturing Apps 8.4 on ThingWorx 8.5 is not a supported configuration and it is expected that you will experience problems.
--Sharon
vinesh
8-Gravel
(To:vinesh)
SOLUTION:
