I created a Thing Template with a base template of PTC.ISA95.PhysicalAssetBaseThingTemplate.
I created a Thing through the Configuration and Setup mashup. I saved and then went back to add a picture. I am unable to save any edits to the General Information section.
I can click on the save button but no confirmation message appears. If I navigate away the changes have also not been saved when I go back to General Information.
Is there a service or anything I need to validate in order to save?
I found my problem. I accidentally allocated a Localized Token to my Equipment Type in the Configuration to point to a Asset as predefined in the Application.
I removed the Localized token which resolved my issue.
