Utility Services for the Dygraph Widget
SOLVED
Regular Member
How I can access/find the GenerateDygraphData service to convert an infotable to CSV. I cannot find the PTC.SCA.SCO.DygraphUtils it in thingworx composer 8.4.
Dygraph Widget Help
Tags (3)
Re: Utility Services for the Dygraph Widget
Hi @nquirindongo
PTC.SCA.SCO.DygraphUtils was introduced with ThingWorx apps 8.5.X (Utilities services have been provided to improve ease of use for the Dygraph widget.). Currently your ThingWorx platform and  Apps versions are 8.4 that why not able to see Thing  PTC.SCA.SCO.DygraphUtils in composer; however the Dygraph Widget is  available with earlier release as well.
Please follow 8.5.0 release note:
https://support.ptc.com/help/thingworx_apps/r8.5/en/index.html#page/thingworx_apps/ThingWorxAppsWN/t...
Abhishek
8 REPLIES 8
Hi @nquirindongo.
The Dygraph widget is delivered with ThingWorx Manufacturing Apps. You'll need an entitlement to Manufacturing Apps to access it.
--Sharon
Hi @slangley
Thank you for your response. I've Mfg. Apps 8.4 installed and I can access/use the dygraph widget from the mashup builder. But also I would like to convert an infotable to CSV (JSON, sent in string format) and using the GenerateDygraphData seems to be an easy way to do it. (only if I can find the PTC.SCA.SCO.DygraphUtils in the composer).
What do you mean by entitlement? Do I need a separate license to access the PTC.SCA.SCO.DygraphUtils from the Composer?
Nelson Q.
HI @nquirindongo.
Apologies for misunderstanding.  You do not need further entitlements if you already own a license for Mfg. Apps.
I'll have to leave your functional questions to someone with experience in Mfg. Apps.
--Sharon
@slangley , You're fine. I didn't provide enough information in my initial post. Thanks for your response anyway.
Nelson Q.
Hi @nquirindongo
Abhishek
Is it possible to get the dygraph utilities in 8.4?
Another option is to write a service with the same algorithm.  Is this algorithm publicly available or is there a way I can find it or one similar in version 8.4 Manufacturing Apps?
Hi @Ascherer17
The dygraph utilities is not available in 8.4. As from the above comments if the requirement is to "convert an infotable to CSV " This can be achieved  by  CSV Parser extension. Follow these steps:
1) Download CSV Parser extension from Marketplace and import to ThingWorx platform.
2) Use WriteCSV function to convert and save files
3. Create a subscription to call the service based on a time event.
Find the document on CSV Parser
Abhishek
Hi @nquirindongo.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
