Where can I get this? The license from developer version doesn't work with this version.
In addition to Steven's response, you may refer to Dual app license install tips
Greetings Chris,
Please refer to the information contained in this article:
Some Q&As in regards to the Licensing changes in ThingWorx 8.0
In particular, that post will bring you to this Knowledge Base article, which describes using the PTC Licensing Tool to obtain a license that reflects your most current entitlement:
Please let us know if you are able to get this sorted out, or if you are still encountering any trouble.
Best regards,
Steven M
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
