I tried to install the 30-days Manufacturing Apps Developer kit Edition but encountered this error "You are not entitled to the Composer feature. Please contact your PTC account team" when running the composer. Is not the developer version should allow access to Composer?
Hi Cheah,
To dig out more into the issue could you please share the below details:
- Exact url/link from where you downloaded the developer edition.
- Exact name of the zip file you installed on your system.
- Please confirm that no previous version of manufacturing apps was installed on your system.
- Are you able to access the Welcome Page of Manufacturing Apps on your system
Himanshu
Greetings Cheah,
In Developer Edition license ThingWorx server automatically shuts down after 30 days of usage and and it is non-renewable.
To assist you further on this could you please let us know when have you installed the Developer Edition and which version of Thingworx and Manufacturing app you had installed?
Best regards,
Himanshu
Hi Himanshu,
I downloaded it from https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard and installed it today. I believe it is version 8.1.
Hi Cheah,
Himanshu
Chea,
You probably downloaded the Freemium version. It doesn't have composer access. In Learn section of that link, you will see Developer Kit, download and install it. That should give you full access.
Hi Himanshu,
Please see my reply below:
- Exact url/link from where you downloaded the developer edition. (https://www.ptc.com/en/thingworx/manufacturing-apps/Dashboard/Download-Developer-Kit)
- Exact name of the zip file you installed on your system. (ThingworxManufacturingApps-8.1.1-00-developerKit.zip)
- Please confirm that no previous version of manufacturing apps was installed on your system. (no other version of mfg apps installed)
- Are you able to access the Welcome Page of Manufacturing Apps on your system (Yes, I can go into the MFG Apps in runtime, but not in Composer)
Can you check the license subsystem to see what license you have??
Hi Varathan,
Below is my License information.
By looking at the image, you installed Freemium and that is reason why you are seeing that error. In you license you are missing Composer. I installed the Developer Kit yesterday and works for me. See the attached image. Go to the portal and navigate Learn section, Download the Developer Kit version, it should solve your problem. Before installing Developer Kit, make sure to uninstall the Freemium.
You can also get the license and replace it as alternative.
Hi Varathan,
I believe I have installed the developer kit, and the license come with it suspecting having an issue. The License you showed above does not look like a trial license, it is self-generated that come with 1 year validity. My concern here if it the developer kit license cannot access to the composer, then other user that downloaded and installed it may have the similar issue. Please look into this issue.
Thank you.
