how to install Manufacturing App with SQL Server database instead of Postgres
ras
Greetings!
                 I want to install Manufacturing App with SQL Server database instead of Postgres database. Is this possible? If yes then how to do that? I have searched for the document for the same but no success. Your response is highly appreciated.
Thanks.
1 ACCEPTED SOLUTION
hchanana
(To:ras)
Greetings @ras,
If you are using trial version installer for installing manufacturing apps, then PostgreSQL is the only database supported  and is installed and configured as part of the installation.
If you are a licensed user, then you need to install ThingWorx Platform with MS SQL Server and import the manufacturing apps extensions over it. This way you can achieve your requirement.
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
3 REPLIES 3
hchanana
(To:ras)
Greetings @ras,
Himanshu
ras
(To:hchanana)
Thanks, @hchanana for your solution. Could you please provide the document links for the same, it will be a great help for me.
hchanana
(To:ras)
Hi @ras,
You can find the documentation at the link https://support.ptc.com/appserver/cs/doc/refdoc.jsp
Please select the required Product and version to filter out the documentation.
Himanshu
