Add Datum Axis for all the Holes in Parts built from Neutral Files
StefanKraml
As per this thread, related issue:
Hi @TomU do you know if there is a working tool for new creo versions too? We use Creo 7.0.4.0 and we're hardly missing this tool!
I do not understand why this is no standard for Creo OOTB ...
TomU
(To:StefanKraml)
According to CS48511, the tool is supposed to be upwards compatible:
Have you tried using the Creo Parametric 3.0 version with 7.0?  If it doesn't work, then maybe open a case with tech support and ask them to recompile it for 7.0 and then add it to the same article.
TomU
(To:StefanKraml)
StefanKraml
(To:TomU)
Seems like our IT has managed to include Version 3.0 of the Auto Axis package to our Creo 7.0.4.0 installation.
Thank you!
