As per this thread, related issue:
Hi @TomU do you know if there is a working tool for new creo versions too? We use Creo 7.0.4.0 and we're hardly missing this tool!
I do not understand why this is no standard for Creo OOTB ...
According to CS48511, the tool is supposed to be upwards compatible:
Have you tried using the Creo Parametric 3.0 version with 7.0? If it doesn't work, then maybe open a case with tech support and ask them to recompile it for 7.0 and then add it to the same article.
Seems like our IT has managed to include Version 3.0 of the Auto Axis package to our Creo 7.0.4.0 installation.
Thank you!
