Hello all, I am putting together a post processor and want to add a G90 whenever a workoffset is called. I assume it is a FIL routine. Any help would be greatly appreciated.
Josh
This little chunk of code from my post-processor is how I handle the offset being set in the CIM file:
CIMFIL/ ON, SET, OFSETL
OFSTYP = POSTF ( 6, 5 )
OFSREG = POSTF ( 7, 5 )
IF ( OFSTYP .EQ. 1 ) THEN
IF ( OFSREG.GE.54.AND.OFSREG.LE.59.AND.CURREG.NE.OFSREG ) THEN
CURREG = OFSREG
OFSCMD = TEXT/ 'G', CONVI, OFSREG, 2, '$'
INSERT/ OFSCMD
ENDIF
ENDIF
CIMFIL/ OFF
Perhaps you could use this to add your own additional commands? The available documentation on doing this stuff is rather lacking. It's like some sort of arcane language.
Taylor,
In your FIL file you may try something like this:
CIMFIL/ON,OFSETL
DMY=POSTF(20)
POSTN/OUT,7,90
DMY=POSTF(21)
DMY=POSTF(13)
CIMFIL/OFF
CIMFIL is the way to capture certain commands in the CL file. In this particular example OFSETL
DMY is the return value for each function. I thas no particular use in this example.
POSTF(20) store the current command
POSTN/OUT,7,90 - output the G90 code
POSTF(21) recalls the stared command and POSTF(13) execute the command.
The G-post and FIL manuals are located in the <load-point>\<Machine-type>\gpost directory:
... Creo 2.0\Common Files\M110\x86e_win64\gpost\V64_GPost_CD_Manual.pdf
... Creo 2.0\Common Files\M110\x86e_win64\gpost\V64_FIL_CD_Manual.pdf
Look at section 2.5.1 in the FIL manual for more details about the CIMFIL routines.
I have been trying something similar (using INSERT instead of POSTN) but it seems to be ignored
It looks like you are trying to output the G91 G28 Z0 and M1 before each tool change? Is this correct?
Yes
Strange. For me is working both with INSERT and with POSTN:
CIMFIL/ON,LOADTL
DMY=POSTF(20)
$$ POSTN/OUT,7,90,7,28,26,0
INSERT/'G91 G28 Z0$'
OPSTOP
DMY=POSTF(21)
DMY=POSTF(13)
CIMFIL/OFF
Also I found that there is one more way to do this. Take a look at the attached picture.
It works at with LOADTL, that is where I insert the G91 G28 Z0 and M01, but I want the G90 for workoffset changes when there is no tool change.
Thank you for working through this with me.
Josh
looking at the CL file, it looks like CIMFIL should be run on SET
from file: SET / OFSETL, 54 but whe I do I get a minor word error.
Interesting is that if I don't use SET then OFSTNO shows up in .lst instead of OFSETL.
Josh
CURREG = OFSREG
INSERT/ OFSCMD
ENDIF
ENDIF
CIMFIL/ OFF
Fantastic!
If any one else uses this you need to set an initial value for for CURREG ( 0 is fine). I commented out the redundancy lines and added a B0, we control index values with the work offset.
Can anybody help me in getting Post processors for HAAS VF4 (HRT210 - 4th Axis) and HAAS ST20Y (Turn mill)?
Your help is highly appreciated.
email: vsnprasad.k@mechoptronix.com
Thanks in advance.
