Adding new menu button in EMX
Abhinand
Dear Team,
Bit curious about above topic. is it possible to add a new button in EMX menu?, My company is using some special standard items, and I want to add it in a separate menu button. regarding icons etc. I will sort it out. but want know is it possible in current setup or not. I am using EMX 11.0.2.1
tschneyer
(To:Abhinand)
Hello Abhinand,
you can not add separate buttons to the menu.
Still you can use the EMX library to provide company inernal library components to your users.
Please check out the related chapter in the tutorial:
Expert Moldbase Extension Tutorial PDF
You can also subscribe to our YouTube Channel.
https://www.youtube.com/user/buwsoft
I will upload Expert Moldbase Extension related videos there!
Kind Regards
Thomas Schneyer
B&W Software GmbH
2 REPLIES 2
I hope @tschneyer can answer the question.
Martin Hanák
tschneyer
(To:Abhinand)
Hello Abhinand,
Kind Regards
Thomas Schneyer
B&W Software GmbH
Welcome to B&W software GmbH We are the world's leading supplier of add-on applications for the 3D CAD system PTC Creo Parametric (previously Pro/Engineer) from PTC. Our goal is to provide users of this innovative system applications that make it possible to work faster and more efficiently with ...
