Margi, are you seeking general comments or something specific like CAD Assembly association? We associate CAD Docs to WTParts. With 10.1 the action "edit association" from the CAD Doc info Action menu will permit asssociation and then requires a Check In of the WTPart. The next Check In of the CAD Doc will also build the wtpart attributes noted with the prompt line in the Creo window. You'll need to understand that now the CAD Doc and WTPart must both have Check In rights once associated. If either does not then the Check In will fail. Also during the Revision actions the wtpart will collect if you start the revision tasks using the Owner CAD Doc
Regards, Jim
In Reply to Margi Korch:
Just curious if anyone would be willing to share experiences on linking CAD
data to existing WT Part structure?
Thanks in advance!!
Margi Korch
Information Technology
Mechanical and Manufacturing Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6097 (office)
+1 520.203.4444 (cell)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
