PTC community,
Is there an auto save option in creo? After a certain time or key strokes. My pro-manufacturing guys were wondering so I thought I'd look into it. I thought maybe a config option.
Please help me out.
No there is not.
The best you can do is get a timer program that pops up and reminds you to save.
Remember the 3F rule of CAD - File Fairly Frequently!
If you have ever used a CAD program with Auto-Save, you would not be asking for it! It saves your files at the most inopportune times.
Disagree strongly with this take.
Autosave insulates against crashes etc. Creo makes it miserable because of the .1, .2 crap. I've had three crashes this morning. All work lost. If I was using another cad program I'd happily go to my autosave folder and pull up a version at most 10 minutes out of date. In creo, all work lost.
As usual, programmed and used by uncreative people who don't even know what's out there.
As is pointed out, this is a standard feature for many microsoft products. Had a crash? Get the latest autosave, work saved. PTC as usual living in the distant, distant past.
What CAD program has an autosave feature?
I have used one that had autosave and everyone hated it. We disabled the option very quickly.
With a program like Creo, what do you auto-save? Only the current work part, all parts releated to your current drawing or assembly or all parts in session. Some of those parts you may not want to have saved!
Learn to save before doing something that is complex. Learn to save Frequently - FFF of CAD rules.
I have lost hours of work too due to Creo crashing, but I would not want an autosave function enabled even if it was in the code!
If using Windchill with Creo, set your system to do an upload with the save so your changed files are put up on the server as an added backup.
Solidworks is the one I know about. I think people are confused by autosave and autobackup. It's not an autosave at the file location. Its an autobackup in a preselected folder that can be accessed after a crash. In that case it would be everything in session. Now think about it: You crash. You have the option of going back to the last save state, where the file is, or accessing the autobackup that has all the work you would have lost. Surely you've lived through a microsoft office crash and have a reference for what I'm talking about?
No?
The whole in session crap is another reason why the program is garbage. Its a relic of Unix days long past. What other software do you have in session file management? Only PTC. Imagine if you had to do that with word files. People would use something else. As they should when given the choice to use PTC products or literally anything else.
100% agree with you. I also came from Solidworks, work with Creo is go back 30 years (or more)...
Everything its complicated on Creo, 0% productivity / customer oriented.
They only continue selling this software because its very difficult /costly for companies to switch to other CADs....
"They only continue selling this software because its very difficult /costly for companies to switch to other CADs...."
Yes, but switching CAD systems does happen!
I worked for a company who had been on Unigraphics for 20 years when someone at corporate level played basketball with a PTC sales rep and got convinced that the whole company should be on PTC products. The company had many divisions with a mix of Unigraphics and Pro/Engineer in use. We were the only division 'forced' to switch to Pro/Engineer. Thousands spent on 3-5 weeks of training for 50 designers. Seven years later the company decides to sell our business unit and the buying company uses CATIA. More spent on additional training as the company does its 2nd CAD switch in 7 years. They still have 1 seat of NX and a few of Creo for the legacy files.
CAD switching is something not so common, most changes are for unification (like your example of one company adquire other company and at certain point they must unificate).
My point is, for a company who have all their data on certain CAD software, its really difficult, time consumming and costly to change to other software, and even if you switch to other, convert the data, etc, you still having the issue with drawings and modification of old parts.
I hope one day someone like DIN or ISO create a STANDARD full format (not step ot iges), who include all the information and drawings. Working this way you will have one standard format, that will make independent the software from the file format. The only issue is that the CAD companies will have to compete and lower the prices of their overvalued softwares, at the same time that they will have to improve it faster than today...
Its crazy be on 21 century with most of the engineering "tools" standardized except CAD formats.
Thanks for the response. The worst part about this software is interacting with users who act like it is somehow "ok" to be so far behind the curve. If everyone I worked with said, yes this is the worst software ever, but we think the switching costs are too high, so we soldier on, then I think I could make peace with that. But to hear that this software is "good" or even "better" is delusional.
I honestly believe that at the top, ptc has contempt for its users, and are just flim flam men pushing whatever snake oil they've got.
If you dislike it so much, you have 2 options!
1 - Get a job at a company that uses the software you like. After all, the grass is always greener where the cows poop.
2 - Offer some constructive ideas on how the software can be improved, not just random complaints that it is no good. Examples and specifics work better than random BS about how bad it is.
Constructive criticism has been offered - and refused, apparently. ADD AN AUTOSAVE!
Hi Shawn,
Ben is correct, there is not auto save option. You could set the following option prompt_on_exit to yes. This option Determines if you are prompted to save objects when exiting a Creo Parametric session.
Amit
