CREO 2.0
mnelson
CREO 2.0
Is anyone running creo 2.0 manufacturing we are supposed to update at my company soon. How is compared to the older versions? Are there any new machining features added to creo 2.0? Any other input would be nice.
HI,
I am working with Creo 2.0 manufacturing for a while now, and from my point of view it's a big inprovement. The whole layout of the ribbon makes it easier to construct the toolpaths. The one that surprized me the most is the surface mill using cutt lines. To get along with the new structure will take some hours, but i definitly don't want to go back to WF5. The biggest change for me was the difference in setting up a new mfg.
Paul
SteveLucas
(To:PauldeRidder)
Matt,
we upgraded after M010 was released. What a difference from WF5. For the most it is a lot better than WF5 once you get used to the interface and get the colors set the way you want them. The white back ground makes my eyes hurt after looking at it for a couple of hours. I now have it set up with a nice soft blue background and really like it. Many improved features in Creo2.0. The trajectory sequences are super!! really like the way it works now.
Copy and paste of sequences seems to be easier also.
As Paul said the new cut line is improved and easier for the most part.
There is a new chamfer and round sequence available but I am not impressed with it. If you select any more than a few surfaces or features to chamfer it seems to bog down the system to a crawl.
The next upgrade to M030 is supposed to be out next week (Nov. 21 I believe). I would wait until that is available
then upgrade.
Steve
