Can any one suggest me steps for getting EMX GENERAL ICON in Creo Mold Cavity..
dyadav
7-Bedrock
I am using Creo 3.O and I installed EMX 9.O but i am not able to find EMX Icon/tooldbar in Creo Mold Cavity interferance...
Dinesh,
I guess that EMX 9.0 installation contains protk.dat. Edit your config.pro file and add the following option into it.
PROTKDAT full_path_to_EMX_protk.dat
Martin Hanak
Martin Hanák
9 REPLIES 9
Dinesh,
Martin Hanak
Martin Hanák
Thank You Martin.....You always be there to resolve any issue.....Thank You.....
I have another ques... How to add Substitiut Feature(Related Flexible modeling) In Manufactring Interferance....
Dinesh,
I am sorry, I do not know Manufacturing mode functionality.
Note:
If you have new question, please open new discussion.
Martin Hanak
Martin Hanák
Mahesh_Sharma
22-Sapphire I
(To:dyadav)
Dinesh,
Flexible Modeling is available for part mode only.
Don't forget to mark appropriate reply as correct answer.
I know that is available in part only...while working in EMX we can use substitute feature which from FMX...
just you have activate that part and have to customise you menu bar.
thank you
Dinesh,
when you install emx it adds a config.pro file in the bin directory for each version of pro.
copy all those lines into your regular config.pro. If you do not have the show_dim_sign set
to no it will not make the die set plates correctly-you will see the plates will not look like
they are in proper order. I use a different config.pro for running an emx session than my
normal pro because of this. at least that is how my emx has been working. there is also
a protkdat line in the emx config.pro.
Dick Adelmeyer
Thank You...It worked...Thank you and sorry for late
tschneyer
6-Contributor
(To:dyadav)
Ryan Kelley‌ please add to Expert Moldbase Extension - EMX
Kind Regards
Thomas Schneyer
B&W Software GmbH
