Center/spot drilling
kpv20
Hello, I am a relatively new user of the manufacturing module in Pro/E wildfore 3.0. I am struggling to find an option to center drill a series of holes that I have in my model. Although I know how to set up drilling a thru-hole I couldn't see an option to set up center drilling (spot drilling) of the holes in 'holemaking' menu. Could somebody help me with this please.
Many thanks
Vk
kpv20
(To:kpv20)
Thanks everybody for the answers you gave. majority of you suggested to use the counter sink option. So this seems to be the most practical way of doing this. However when I used this option I found that all the option in the 'hole depth criteria' menu within the hole definition window are greyed out. So I cannot set the depth. Does anyone know if this is because I could be doing something wrong?
Vk
I wanted help or tutorial for welding in ProENGINEER 2.0. I am not able to do spot welding.
i need to work on create many spot welds remove a report if possible and find out which is on which panel and so on . Help me for the same
