Chamfer back of hole
Mickyd1
hello guys
ive got to machine a chamfer on the back of a 25mm hole using a 16mm dia dovetail cutter,ive tried using trajectory milling but the cutter just comes down through the component,how do i get the cutter to come down in the centre of the hole then machine round the back of the hole.
thanks for any help
SteveLucas
(To:Mickyd1)
Michael,
this what I do to get any tool to start in the center of any diameter hole. take the hole diameter minus the tool diameter times .208 to get the leadin leadout amount. then set the entry angle and exit angle to 135.
In my example picture the hole diameter is .375 and the cutter diameter is .250 so the math is .375-.250=.125*.208=.026 this value goes in the lead_radius and tangent_lead_step as shown in the picture.
As you can see in the picture it makes an nice entry and exit back to the center of the hole.
6 REPLIES 6
SteveLucas
(To:Mickyd1)
Michael,
Thanks Steve
is there a formula i can put in the required parameters so i dont have to work it out each time?You do seem to help me out a lot cheers.
michael
SteveLucas
(To:Mickyd1)
Michael,
I have never tried to automate how the formula is calculated from within Pro? Not sure how to do it? maybe some one else has an Idea.
I do it so much it's just automatic for me.
Steve
If you want to build in automation check this site out http://www.codexcreo.com/AE_UDF.html
The idea here is to build the manufacturing information into the feature (hole) and then apply those settings automatically in the manufacturing file. I have never gotten it to work but maybe you can figure it out.
SteveLucas
(To:NickMihelich)
I have looked at annotation features a little bit but not sure if it would work for this situation because you are kind of locked into the tool diameter with my method of leadin leadout. I also can't rely on engineering using the annotation in their design. I would have to add the annotation features myself to use them.
Right but i was thinking you could incorperate some parameters. You could in theory build the expression right in your manufaturing seqence parameters something like (hole_diam1 - cutter_diam)*.208 =
Just a thought.
