Collision awareness in NC Manufacturing.
MT_13761869
2-Explorer
I am trying to find a good way to set a collision or avoidance region away from my fixture. Is this even possible within creo, or is everything just set automatically? I know you can't add the fixture as a check surface in any of the operations because it isn't the reference model. So where exactly can you configure your fixtures avoidance regions?
4 REPLIES 4
Hi @MT_13761869
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
Using module works simulations (built in to creo) you can set a distance to warn you about collisions within a distance range. Default is 1.00
Hello @MT_13761869,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
You might not be able to use the fixture as a check surface, but maybe you could build a simple surface within the manufacturing assembly itself, based upon the fixture.
Alternatively, you could load the fixture in as an additional reference model. Creo will let you load as many reference models as you wish, so maybe this will let you use the fixture surfaces, too.
