I currently have the following code for a countersink sequence:
$$* Pro/CLfile Version Wildfire - M260
$$-> MFGNO / MFG0001
PARTNO / MFG0001
$$-> FEATNO / 106
MACHIN / MILL, 1
$$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
UNITS / INCHES
LOADTL / 9
$$-> CUTTER / 0.375000
SET / OFSETL, 1
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
SPINDL / RPM, 7800.000000, CLW
COOLNT / ON
RAPID
GOTO / -4.7500000000, -0.5000000000, 0.5000000000
CYCLE / CSINK, DIAMET, 0.106000, TLANGL, 120.000000, IPM, 35.000000,
CLEAR,$
0.125000
GOTO / -4.7500000000, -0.5000000000, 0.0000000000
CYCLE / OFF
RAPID
COOLNT / OFF
SET / OFSETL, OFF
SPINDL / OFF
$$-> END /
FINI
We have a Mazatrol 640M controller and I don't believe it has a cycle
for countersinking so right now we have NA listed in our post under the
Machine Codes->Prep/G-Codes->Cycle/Csink.
Does anyone know how to setup the post to correctly use the countersink
cycle? Is it something I need to add in the fil file or is there a
cycle for the 640M controller that I am not finding?
Thank you,
Michael Wolf
