I am using Creo Parametric Release 8.0 and Datecode8.0.7.0
I am having some issues in Creo, while generating the NC or trying to edit the sequence, it shows fatal error and Creo crashe
Here are the errors that I faced
fatel error encountered. A tracebake has been written to C:\Work\proefiles\traceback.log
Article - "Recommendation of handling Creo Parametric exits with 'Auto Traceback Info' dialog having warning, "Fatal error encountered. A traceback has been written to C:\Users\Public\Documents\traceback.log."": https://www.ptc.com/en/support/article/CS49550
