Question: On a detail drawing with multiple sheets, each sheet having a different model (sub-assembly or part) being detailed on it.... is there any way for Pro-E to know what model is on each sheet, so you don't have to remember (ie: before balooning or adding a BOM) to select the current model from the list at the bottom of the sheet. It would be so nice if, once you place a view on a sheet,... that model is always the "current" model for that sheet.
Chris Benner Designer II Powell Fabrication & Manufacturing, Inc. <u>www.powellfab.com P: 989-681-2158 F: 989-681-5013 </u> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Left click once on the drawing view and then RMB (hold) and select "View Info" - this will tell you the following: - View model - View name - View type - Simplified Rep (if any) - Sheet Number - Exploded State info - View Display info - Layer info
