Disappearing Datums
CBenner
Disappearing Datums
Can anyone please explain why datum CSYS on certain parts (pipe fittings) will suddenly become hidden without any user setting them that way? We have family tables of fittings with a "port" (csys) on either end, as well as default datum planes, several axes etc... depending on the part. Regardless of the part, it seems that anytime we need to re-define it in any way, whichever datum we need toplay with has been hidden at the layer level. We have to open the part, unhide the datum, savce visibility and go back to our assembly. Day or two later, the same part will have hidden datums again. There are only two users, and we are within site of each other... so I know no one is messing with us.
Any thoughts?
Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u>www.powellfab.com</u>
P: 989-681-2158
F: 989-681-5013
Confidential
The information contained in this communication is confidential and may also be subject tolegal privilege(s). This information is only for the limited use of the individual to whom it is intended. If you are the intended recipientyour use is strictly limited to your knowledge and use of the information only and you may not forward, distribute, disseminate, copy or publish this information in writing or verbally to otherswithout the express written consent of the sender and/or creator of the information. If you are notthe intended recipient or the agent or employee responsible for delivering this e-mail to the intended recipient, youruse, dissemination, distribution, copying, forwarding, or publishing ofthis information, in anymannerwhatsoever, isstrictly prohibited. If you have received this e-mail in error, please destroy it immediately and notify the sender by telephone at (989) 681-2158 or by return e-mail. Thank you.
<u>
</u>
Chris Benner
Autodesk ® Expert Elite
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
