Hi All,
For multiple users with diferent Sales Order numbers, is it necessary to each user download the zip files on their machine
I am trying to avoid multiple simultaneous bandwidth draining downloads.
Does that make sense?
Thanks to Sarah and Randy.
Randy is correct.
You only need to download once.
I personally install Creo Paramertic once as well. All my users run the software from a network server install. This makes life easier for me and allows me to install new builds easily.
I simply have a batch script that users launch on their desktop. This looks like their Creo Parametric icon but it launches the software from a Network location. When I install a new build, I keep the current build just in case I need to revert back to it. I can install a new build or version of Creo Parametric while all my users are actively working with it. When I am done with the new installation, I simply open the batch script which also resides on the network and change the install path to the new one.
The next time my users launch Creo Parametric, they will be running the latest version or build and don't even realize it. It's the same icon they click on every day.
As long as you have good to excellent network speeds, this is a great way of doing things.
ΜΟΛΩΝ ΛΑΒΕ
