Enhancement Request?
mbraaten
We are having issues creating the following toolpaths with Pro/E. Please note that this is currently possible in MasterCAM.
The goal is to rough the following mill surface with a ball nose end mill in a helical type of motion - keeping a constant helical depth change all the way down:
Here is the mill surface:
When using Cut Line machining with a helical motion the toolpath looks like this. As you can see the helical motion between the spherical and conical part of the mill surface is not a constant plunging depth. This type of tool motion would be fine for finishing the surfaces but we are helical cutting into solid material:
I did create geometry that the tool follows to create the following sequence. This is possible but took a while to create a number of features to accomplish this:
We would like to ask PTC to enhance the Cut Line Helical milling output to provide a constant helical plunging motion down the entire mill surface.
Has anyone else made a request from PTC to change this?
Best regards,
Michael Braaten
Synthes
5 REPLIES 5
To whom it may concern:
Development is working on the issue… See the picture attached, that shows a test result done with a special xtop (only internal).
Daniel Santos - CAM Support
GE Vetco Gray - Jandira - A GE Oil&Gas Business
Mike,
Good news for cutline machining....
From Creo Elements/Pro (WF5.0) M070 you can use the config.pro options :
Inner-cutline and Steep_stepover for extra slices on steped holes
cutline_z_slices yes
Steep_Stepover - Drive the stepover at the selected inner cutlines...
Best regards,
Daniel
I know we discussed this before and the solution was posted here, but I'd like to share some screenshots from Creo/Elements Pro M070 with Mike's problem solved:
The picture above is no longer from another CAD/CAM system... 😉
Thanks PTC and customers who reported this issue...
Best regards,
Daniel
Good Afternoon.
I have a 65mb ncl file. Vericut starts playback but a little ways into the
verification at the beginning of a new tool vericut exits with no warning
messages. I am running WF5 M070 on a dell T5500, 3.33 xeon, 6gb memory,
Quadro FX 4800 using Nvidia driver 266.45, win 7 pro 64 bit.
Has anybody seen this before? Any suggestions on resolving?
Dale
ArtinB
(To:mbraaten)
Vericut had this problem in Rev. 7.0.0.
You need to upgrade to a newer version to fix this problem, we had the
same issue.
<blocked::blocked::<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:-">">mailto:->
Artin Baghdasarian
Sr. Manufacturing Engineer
Aerospace *
Hydraulic Systems Division
4690 Colorado Blvd. Los Angeles, CA 90039
*Tel: (818) 409-0238
*Fax: (818) 409-0381
* E-mail: -
