Export Waterline Center lines
dplachinski
Has anyone come up with a way to export the centerline of cooling lines or solids of cooling lines from a mold design? We are being requested this from customers and simulation contractors.
3 REPLIES 3
Hello dplacinski,
in case you are working with Expert Moldbase Extension you can achieve this by using the Extract Waterline Model fucntionality
Help Center - Chapter Extract Waterline Model
There is an Option call Create mold flow curves for analysis
As a quick summary:
1. Extract Waterline creates a new part/assembly which contains cooling surface (Can be created by EMX cooling components or PTC Waterline Feature) and other cooling related information (Solids/curves)
2. In case option Create mold flow curves for analysis is used all Sketch features with curves that contain the Integer Parameter called FOR_MOLDFLOW the Curves will be extracted and added to an individual model which summarizes all curves.
You can have a look to the EMX Tutorial chapter for this feature as well on our B&W Software Website:
B&W Software Tutorial - Extract Waterline Model
Kind Regards
Thomas
Kind Regards
Thomas Schneyer
B&W Software GmbH
@tschneyer thanks for the reply. However, we do not have a license for EMX. I was looking for a solution in Cero Tool Design Extention.
Hi @dplachinski ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
