Hi to all I'm working with a casting part that need to be machined, i want to use the external geometry option in order to simulate the machining operation and have the casting part dependable from the original file so when i make any change on this machining model will be updated automatically The issue is this, i create a new file (prt) but the option is not available (insert/shared data/geometric copy). How can i make it If you have any other option to do this i will apreciate Regards G. Oviedo
