External geometry
GilbertoOviedoV
External geometry
Hi to all I'm working with a casting part that need to be machined, i want to use the external geometry option in order to simulate the machining operation and have the casting part dependable from the original file so when i make any change on this machining model will be updated automatically The issue is this, i create a new file (prt) but the option is not available (insert/shared data/geometric copy). How can i make it If you have any other option to do this i will apreciate Regards G. Oviedo
The terminology used in the question is a little different from what I know but I think I know what you mean. What you're looking for is the inhertance feature (Insert : Shared Data : Merge/Inheritance), not the Copy Geoemtry Feature. Also, you need the Advanced Assembly license for this so make sure you have it.
