WHAT is up with these!? Can only be added as a cosmetic feature, and the thread data needs to be hand entered into a Pro Table?!?! Why are these not set up like internal threads, where you simply pick the surface, and select the thread form you want from a pulldown list? Is this going to be updated anytime soon? I'm using WF4 M050. This is a pretty archaic tool IMHO.
Ok,... rant over. Back to work.Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u>www.powellfab.com
P: 989-681-2158
F: 989-681-5013
</u><u></u>This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Chris Benner
Autodesk ® Expert Elite
