Face milling sequence.
jarrodmaston
Hi Gurus! I am milling parts from rectangular to trapezoidal. Using an
anle plate and sin bar to prop the block up, and programming with a "face"
sequence. The workpiece top is at an angle to the face surface. When I
pick "trim to workpiece", it doesn't change the toolpath so the cutter
rapids into the leadin distance. Is there something I'm missing? I'm using
relrase 2001.
Jarrod
0 REPLIES 0
