Facing Direction
MDrake
8-Gravel
Facing Direction
I am looking to change the direction the tool moves so that it moves down the face of the part with each pass.
It wants to cut in the z direction.  I would like it to cut in the x direction.
I believe this yellow arrow has something to do with it.  Is there a way to rotate this arrow?
slolli
(To:MDrake)
Hi, in the parameters for the Face milling toolpath, change the CUT_ANGLE parameter from 0 to 90.
2 REPLIES 2
slolli
(To:MDrake)
MDrake
8-Gravel
(To:slolli)
Thank you!!
