I am looking to change the direction the tool moves so that it moves down the face of the part with each pass.
It wants to cut in the z direction. I would like it to cut in the x direction.
I believe this yellow arrow has something to do with it. Is there a way to rotate this arrow?
Hi, in the parameters for the Face milling toolpath, change the CUT_ANGLE parameter from 0 to 90.
