Family Table / Repeat Region Question
tgiauque
Pro/E Wizards,
I have a table on a drawing. This table lists all the instances for a particular family table and some associated parameters for each. I would like to be able to choose which instances are used in the table - I have one instance that I want to delete. I can go into the "Filters" section of the repeat region menu, but I don't know how to word the filter to eliminate this particular instance. I know this can be done because one of our other product groups has used it on some of their drawings. (Of course, the guy who set that up is no longer with the company.) I'm on WF4.
Thanks!
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
Put in a filter that says
fam.inst.name != <instance name=" here=" and=" yes=" you=" can=" use=" wildcards=" to=" make=" <br="/>a filter work for many items>
Brian S. Lynn
Technical Coordinator, Product Engineering
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
