Fill/Mill
ptc-2324632
Fill/Mill
Is it possible to fill back in a milled out area ?
Not applicable
(To:ptc-2324632)
I guess there are many approaches; here's one, assuming you've got a cube with a simple milled pocket. Select the milled face (yellow in the screenshot), right-click and click ""Align"", choose a reference face as indicated by the second arrow.
Not applicable
(To:)
Another approach is to cut the pocket. Select one of its faces, right click and choose ""Cut faces"" in the context menu. In the dialog, click ""Rec. features"" and reselect one of the faces in the pocket. Click OK.
