Flashforge Gוider-3-ultra 3D printer
Rami_Noah
recently bought the printer mentioned. today i'm working with the software provided by the printer manufacturer for the sake of adding support & slicing etc.
As a next step I would like to print the model directly trough Creo ( 11 ). did any of you have an experience with that ? any specific tips or suggestion ?
Many thanks,
2 REPLIES 2
Some useful materials:
In 3D printing use Slice to create a file which contains all slices needed for printing. CLI (common layer interface) files are created and then used for 3D printing. The CLI format is widely used by metal printers to produce parts created in additive manufacturing. This improves the printability
Hello @Rami_Noah
It looks like you have a response from a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution. If you found a solution yourselves, please document it in your topic and mark it as accepted solution.
It will surely help other users who may have a similar question.
Community Moderation Team.
